adileo
Hi guys
When I 1st bought the 52 F1 (all stock v8), it use to rap / backfire through the exhaust, when backing off on gas. I did a tune up about 3 months ago, adjusted timing and it stopped. At the same time I installed a new carb. Tonight it started again, only when coming off the gas. When at idle it seems like the idle is too slow.
Now I have (I am guessing) two options:
1) check timing
2) turn carb idle screw up.
Which would you go for first?
1) check timing
