Rams Horn Bolts
Subsailor
Hello folks. Anyone have a source for the header bolts for rams horns on a 272? They are two different lengths. I found one vendor (CJs), but they are out of stock. Thanks, Glenn
I don't recall there being anything special about the exhaust manifold bolts for a Y-block.
I would suggest ARP as a source for good high quality bolts. Victor/Macord use to make a very good gasket w/heat shield for the rams horn type of exhaust manifolds.. Keeps the oil in the rocker arm area from cooking.
The rams horn manifolds are very prone to coming loose if you use poor quality bolts.
If you can find a set of rams horns for a '55-57 T-Bird with dual exhaust you can eliminate the front cross over pipe on your Y-block. The left had manifold will have a rear drop in lieu of the front. I have the part number for the Bird manifolds.
Use ordinary bolts - those bolts were nothing special. Just make sure the ones you get don't bottom out in the hole.
Still available -
411560
Notice that they also incorporate the spark plug heats shields. Two birds with one stone TECH.
411561
