Raised tie rod arms?
CJStefan
So I just woke up to make my daughter a bottle and a thought popped into my head...has anyone ever bent the tie rod arms up as opposed to heating/bending the steering arms down? I'd rather bend mild steel than cast.
I'm in the process of redoing my front suspension and I'm flipping my uprights on my '49. I was looking for dropped tie rod ends but I'm coming up with nothing.
CJStefan.... I'm not familiar with the pieces on a '49 and later front end, but just realize that you CAN NOT heat and BEND cast iron!
BELOW is a link to these dropped tie rod ends.
Coop
https://www.speedwaymotors.com/Speedway-1948-64-Ford-Pickup-Truck-Dropped-Tie-Rod-Ends,50152.html
Early Willy's tie rods have female ends and work with an early Ford tie rod.
The main reason you need to bend the arms is to clear the axle when the axle is dropped. If not, you'll reduce the amount your spindles can turn side to side. If using '32-'34 spindles, it also messes with the steering geometry if you don't drop them as well.
Who said the spindles were cast?
Coop
I was thinking about getting those actually but there almost twice as long as the factory ends. One of the thoughts I had was cutting the tie rod and rethreading it to make these work but I wanted to see if there was another way first
My car is a '49. Not having bumpster is my biggest concern
This is 1939 Willys tie rods.
