Wipers on a Model A are an ornament; Rainex is far superior if used properly.
Simple question ................ and not meant to offend anyone ........... If water doesn't get in there when you wash the car, why would a spray of RainX (or, as someone suggested, a cloth otherwise saturated with RainX) cause any more of a problem? Although, my wife tells me "THEY SAY" we shouldn't leave medicine in the MEDICINE CABINET in the bathroom because the humidity when we shower will SOMEHOW get into the pill bottle and weaken the meds deeming them useless. My solution? Take Navy showers ............ get in, lather, rinse, dry, done. LOL !!!! Good luck.
Thanks Bill. I stand corrected and totally understand that explanation. Bob
Your car DID HAVE SAFETY GLASS when it left the factory. At some point it was replaced with plate glass.One question would be:
Why do you still worry about the original glass? For safety sake, replace your glass.
I thought my car had the two layer safety glass from the factory until I replaced it and found it was plate glass.
There is also single sheet safety glass - tempered glass. It breaks into 1,000s of pieces when it breaks. It's not good for windshields but most cars since the late 60s use it for side and rear glass - because it's cheaper and lighter. Tempered is harder to cut/modify than safety plate so it's seldom used outside of its original design.
