Robert/Texas
I have been having trouble lately with my ‘28 roadster wandering on hardtop roads. We have had flooding in this area for the last two years and the roads have shallow dips and steering ruts. This has caused me to notice the problem more than before the rains.
I have removed all of the slack/looseness in the front end and steering and this helped some. My wife and I measured the caster per the instructions in Les Andrew’s book and found that it was only about a quarter of what it should be. We did many caster measurements and all of them came out the same. Les Andrew’s book suggests that the radius rod socket could cause this problem so I bought a new repair kit from one of the vendors. This kit is supposed to be an exact copy of the original.
When I began to install the kit I noticed that the two special bolts included looked slightly larger in diameter than the old ones so I decided to replace them. Big mistake! I got one out OK but dropped the other one down in the clutch/flywheel housing. Yesterday I spent hours trying to fish out the bolt with a skinny magnet, a grabber tool and 90-degree needle nose pliers but to no avail. I could see a few threads from the bolt and it appeared to be jammed just below the clutch. Inserting my finger in the hole (where the radius rod socket fits) I could rock the bolt but could not get any purchase to pull it out.
Today I removed the cover from the top of the clutch/flywheel housing and hand cranked the engine to try and bring the bolt to the top. The clutch/flywheel assembly jammed after a quarter turn (?) so I jacked up the right rear wheel to turn the engine backwards. I suspect the bolt fell forward into the clutch/flywheel cavity and I can no longer see or feel it from the radius rod socket hole. Further I can’t feel or see any sign of the bolt thru the small weep hole at the lowest point of the clutch/flywheel housing.
At this point I was able to turn the engine in either direction by turning the jacked up left rear wheel but there were some grabby points when doing this. After a few turns, back and forth, the grabby points disappeared. Next I cranked the engine with the starter. Again I heard a slight clunk but this quickly disappeared. Now the engine cranks smoothly.
I assume that the bolt fell into the cavity and I could probably reassemble everything and run. However, the risk is that the bolt might move into a vulnerable position while going down the road and who knows what might happen.
I really have little desire to remove the rear end assembly or pull the engine to open up the clutch/flywheel housing. All suggestions will be appreciated.
Thanks Robert.
Thanks Robert.
