TomInCologne
Hi guys,
the radius rod ball kit original style A-3440-s does include the two bolts to which everything is fastened on. I am not in front of the car right now bt if my memory serves me right, the bolts come from inside the gear box or bell housing? So, to swap them you need to take the car apart much further?
If you justwant to swap the ball, do you use the old bolts?
And is there any advantage or limitation to use A-3440-S instead of A-3440-RE?
