Brentwood Bob
Long pin in diagram that hold the felt in place I believe. Don’t turn the bolts and you should be golden.
I've run into most problems associated with the radius rod ball joint assembly. The most common problem is deterioration of the bolt counter bores where the head seats. They like to wear out. I have been fortunate that they tend to wear evenly on both sides. This allowed me to get spacers to use under the bolt heads and put the heads back up to where the pin will still retain them from turning. This defect, if present, causes the bolts to be loose and protrude too far which just compounds the problem.
The other issue is lubrication. While the felt pad will hold oil for a while, it doesn't seem to last all that long in practice until the rear main starts to leak more. I drop the ball down a bit now and then and apply grease to the components. This seems to work a lot better in the long run. A person can pull the pin and squirt oil in there to wet the pad if they choose to use oil in there as Ford intended. I do a little bit of both but just remember not to mess with the bolts until the pin is back in there.
An attorney term for DEATH WOBBLE....The rubber deteriorates and allows unacceptable movement over time. .
Yes and no. It could be used on worn balls, but its also where Ford production on MANY Ford products went after the Model A Era.Use the rubber liner if you want but it's not a better product. It was more of a band aid for worn parts.
Any semi-solid grease such as would be used in a "screw down top" grease cup.
Google AI explains it more accurately than I.
The grease of my familiarity would be the No. 2 above, which for me comes in a plain pint paint can.
Joe K
