I am in the process of pulling the engine and transmission at the same time. I have already removed the bolts holding the transmission to the shorter of the driver shafts. I already picked up the engine till the small hit the frame (by accident), and I tried to pull the engine forwards until I figured out that I had completely overlooked the radius ball. I really hope I didnt mess up the mounting, theres are a 1/8 to 1/4 inch gap on the back (rear) side of the radius ball cover where it is pressed to the frame. Is this normal or did I do some damage?
And since the bolts are spinning as I attempt to remove the engine and ****** together, do I need to remove the ****** from the engine in order to gain access to these bolts to stop them from spinning? Would it be possible for me to pull these bolts down to stop them from spinning, Ive read something about hows there is a pin or slot in the head to stop it from spinning, could I get pictures of this inside the transmission so I get a better idea of what I am working with?
Sorry for the long post. And thank you in advance, Ill post my results once I am able to seperate the transmission from the engine, which I will hopefully be able to do after I remove them from the vehicle as one piece.
