Radius Arm
lasermangene
Looking for radius arm for 31 tudor that fastens to Fornt Spring Perch live in Michigan can anyone help me out,... Thanks
Hi,
You're refering to the "wishbone" that attaches from the center rear of the flywheel housing to the spring perches? Check out ebay there were a couple of them(about $100.) on this past couple of days. I have one which is not that bad condition was saving it for backup. It is straight, just a little rusty on the underside of the rear mounting point. let me know if you can't locate one. I am in Florida, Bill H. 321.454.4490
When you find one, be sure it's straight. I've seen lots of bent ones at swap meets. A bent one will affect your front end caster and maybe cause wheel wobbleing
