47COE
Funny thing is that the static is greatest when the engine is first started and decreases over time and speed (20-30 minutes/miles) until it's all gone until I pull into the garage again at idle and it's back.
That sounds like the static is related to charging. After you start the car it is charging a lot but as you drive it the charging slows down as the battery reaches full charge.
So I'd suspect either the generator or the voltage regulator.
If you plug headphones directly into your CD player do you hear the static?
Tom
