Forker, did you check to be sure that the antenna is good and plugged in? if not you'll only get static. Is your radio the zenith wonder bar type? does the dial or bar move, I believe there is an adjustment screw on them as well, there is somone that sells a reprint of the schematic, and information. Check on ebay
