S steward614 Junior Member Apr 25, 2019 #1 Hello I have a 31 radiator shell and purchased an aftermarket black script FORD top badge to be installed. It has the "cup" behind. Whats the best way to flare the cup without damage to install?
Will N Well-known member Apr 25, 2019 #2 I believe that with original parts, that cup is a snap-in fit into the hole in the shell. But if yours is lose, maybe some silicone to hold it?
D duke36 Well-known member Apr 25, 2019 #4 I have a repro that the cup separated from the front logo portion poor rivet assembly. GE Silicon sealant has held well
Tom Wesenberg Well-known member Apr 27, 2019 #5 My first choice for badge to cup separation would be to rough it up and use JB Weld. As mentioned, the cup should be a press fit to the shell.
