radiator question
Mike/Nebraska
I just bought a radiator for my 29 from out of state. When it arrived it is somewhat different than my original. First of all it has a shroud, but it doesn't bolt on, rather it is part of the tin surrounding. Secondly, when I put my shell on it, all the holes line up right but it only has about two or three threads of the neck sticking out above the radiator shell. Third...The upper neck is shaped different. It kind of curves down along the shroud and then curves out in sort of an S shape. Also the lower radiator tank partially blocks the crank hole .Could this be from a tractor? If I had the neck extended is there any reason it wouldn't work on my car, which is not all original anyway.
You have one from a commercial application. Either a stationary engine or a combine. They don't work on a car.
