ericr
Ah, but you could run a car without a radiator shell, you can't run it without a radiator. So, which would you rather have it you could only afford one thing? Driving your car, or having a car with a perfect shell sitting in the garage because there's no radiator? Is there a better chance a professionally done radiator will fit in a perfectly done orginal shell-sure. But, that does not preclude that an aftermarket radiator won't fit in a repro shell.
Now, would you buy a repro radiator from a reasonable supplier with real contact numbers, or an NOS shell on Ebay if the price was the same?
all of the above is why I would send whatever shell I was using to Berg's or whomever before buying a new radiator of any type. and the '29 shell design is a little problematic anyway, with the tight fit between hood shelves, and the overhanging lower edge pressed against the felt pads. I've seen original '29 shells with fractures at that lower edge, and also, with hogged-out mounting holes.
