50Pickup
I have a 1954 Ford Crestline Skyliner with a Flathead V8, in Canada 1954 was the last year of the Flathead. I was cruising at 55-60 mph when a loud grinding noise came out of the engine. Pulled over, my rad was leaking and a large circular imprint of the fan was on the rad and two hole were punctured in this circle. One of the fan blades was slightly bent in at the end but all three fan blades had proper clearance from the rad including the bent blade. The rad looks solid and the fan also seems solid so I can't figure out what caused the rub and puncture, could a foreign object have fallen in between the fan blade and the rad ? did anyone ever experience this ?? Thanks for your help
