Radiator Mounts on 1941 Super Deluxe
Walton Feep
Hello all,
I installed new water pumps and I am installing a new Walker radiator. The old mounts were kind of a mishmash of rubber, bolts and nuts. I ordered a kit from Macs. Each side contained a square rubber with a hole in the center, two springs, a bolt, a castle nut, and cotter pin. No instructions. In what order do the parts go? I assume the bolt comes up from the bottom of the frame through the correct hole, but then what? Do I need both springs?
Also any tips on connecting the new lower radiator hoses would be appreciated.
Thanks in advance!
Hugh
The rubber pad goes between the radiator mount and the lower frame flange. The bolt goes down from the top, spring installed from the bottom, then nut, then cotter pin. Don't compress the spring but just a little.
