Brent, what is the relieve valve in this system? I would be concerned about an engine getting hot enough to generate steam.
I thibnk it will be a while until we need to worry about overheating a Model A on the moon.Water column is 0.44 psi per foot. So 5 psi would be 11.25 feet. Fresh water weighs about 64 pounds per cubic foot. There are 144 square inches per square foot, so 1 square inch by 1 foot high is 64/144 or 0.44 pound or 0.44 psi.
The mass is the same but the weight on the moon is a lot less so the column of water would have to be a lot higher. I think the water may boil off on the moon anyway because of the low atmospheric pressure there. If it gets cold enough because of the evaporation it will turn to ice but probably sublime anyway, like dry ice here on earth.
Back in the dark ages, we engineers used manometers to measure pressure. A whole rack of manometers were used for any significant experiment. The manometers were nothing more that a set of U shaped tubes with colored water in them. Mercury was used for higher pressures.
In a vacuum would that model T produce any compression or would the engine run in reverse?
Extraterrestrial VehicleIt's an EV
