fordfun
After living with a leaking water pump for the past 2 years ( and trying several fixes including tightening, repacking, etc.), I finally bit the bullet and installed a "leakless" unit. This seemed like the ideal time to replace the 4-blade fan that came on the car (1929 Sport Coupe) with a new 2-blade Al. version. This necessitated removing the radiator, which revealed that it did not contain the spring mounts, so I installed these. I also re-plumbed the rad. and installed a petcock (which had not been previously installed...what a mess draining the system without one).
The pump and fan are now installed and the radiator is back in the car. However, I believe I may have a significant clearance problem, particularly at the 6:00 o'clock position of the fan (about 1/8" between tip of blade and radiator). The clearance improves higher up, which appears to indicate that the fan blade is not sitting parallel to the rad. Should it?
I'm concerned that any movement of the radiator aft may result in contact with the fan. The only retarding factors are spring pressure on the mounts and the lower hoses. Also, if the pump or fan ever need to be removed, it will definitely require pulling the radiator.
I could move the bottom of the rad forward a bit, but that would give only minimal improvement and opens up a gap between the hood and the shell.
Is this situation unusual and a problem? If so, How would I go about correcting it? I'd appreciate any insight and guidance you can give me with this.
Thanks - Bill
Thanks - Bill
