Radiator Dimensions
40fordpu
I believe it to be a correct size radiator for my '40 pickup. The dimensions are 21.5" wide, 21 1/4" core height, 25.5" from bottom of tank to top of tank, not counting that little nipple. The mounting holes for the bracket are 5" from bottom of tank and there is a slide like hole in side of radiator, 14" from bottom of tank. GOTA A PIC POST IT.
What do I have if it is not a "40's" radiator? What application is it for?
Thanks again guys for all your help!!!
I just measured mine, the dimensions you posted are the same as mine, bracket mounting and all, with the exception of the "25.5" from bottom of tank to top of tank, not counting the little nipple", mine is approx. 27.5", I measured from extreme bottom of tank, not the core. Sorry, no pics.
