I've never heard this before - does any coolant ever go into the overflow tank?Been running my 8BA with no pressure since 1950 and never overheated once. I remove the lower seal on the cap and use an overflow tank, so my rad is always full to the top. I do have to add coolant occasionally. Not very often.
Yes it does, Blu. I used an overflow tank from a brand X S10 and the coolant transfers back and forth great. I like it because the rad is always full. Using 16o thermos it runs between 160 and 180 year around. Hope it works for you.I've never heard this before - does any coolant ever go into the overflow tank?
Mine is a EAB ('52 Customline) - got it last Nov and I think it's still trying to find its comfort level. Since I don't drive it very far I've wondered if it would be best to not run a pressured system. I'm installing a overflow tank right now as a precaution.
B-O-B, do u have the large top tank on ur radiator?
