KenCoupe
I have a 31 coupe with a motometer. The car also has an alternator. It runs cool (no red in the motometer). However, occasionally the radiator will bubble out from the bottom of the motometer where it meets the radiator neck. I use straight water with some water wetter to help prevent rust. There is no antifreeze. It is kind of a foam that bubbles out. It is a relatively new Brassworks radiator and I have flushed it out. I also took some of the tension off the belt around the water pump and alternator. That helped a little, but it still bubbles out.
Does anybody have any suggestions on what is causing the foaming and bubbling out, and how to prevent/stop it?
Thanks.
Ken V.
Thanks.
Ken V.
