dennismielke
Can I run radial tires on 34 stock wheels without innertubes? Or do I need special innertubes and do I need to run a liner over the spoke ends?
Any comments appreciated
I had 35 spokes on my '33 and ran tubeless radial tires.Won't work with a 17 or 18" rim because of the valve stem hole so you will need tubes.
deuce lover
What size 16" radial tires did you use?
175/75 R 16C front
215/75 R 16C rear
