flathead 53
I just read an article on running radial tires on older cars, that originally came with bias tires , they said if using radials on older vehicle, set the toe at zero. not at the factory setting recommended for the stock bias tires, my 53 f100 factory specs calls for 1/16th toe in. I am running radials I should change the setting to zero toe. anyone have A take on this
