8EL
I can not seem to find specifications for tubes suitable for AMERICAN CLASSIC RADIAL - 475/500-19 WW tires.
Coker's technical help line told me that "although we say our tubes are for use with bias ply and not radial tires, it is OK" I Have a problem with that....
Universal Vintage Tire Company sells the same tire and lists this as a related item to them:
Description
475/550-18/19 Bias Tube
TR-135 Center Rubber Valve Stem
Intended for use with the following Bias Ply (Cross Ply) tire sizes:
525/550-18 (for wheels using center valve stems)
475/500-19
525/550-19
Yet they sell a tube for radial tires or bias ply for three and a half times more money indicated as such:
Description
500/600R19 BR-19 Radial Tube
TR-150 Center Rubber Valve Stem
Intended for use with the following Radial or Bias Ply tire sizes:
475/500R19 475/500-19
525/550R19 525/550-19
If the more cost effective tube is acceptable, why would I spend that much more for these?
Snyder sells a rubber stem tubes advertised as 100% butyl rubber for this application.......
I am sure that others have installed these tires on their A, what tubes did you use???
Description
475/500-19
525/550-19
Description
