quick question 1934
Ken Arms
I cant remember if the outer ujoint cap goes on with grease zerk up or down? I think up since that would put the battery ground tapped hole on the same side as the battery. True or false? Thanks Ken
Tapped hole top left as you thought . The zerk placement on the right side is different 33-34 with 33 being lower like 32 and 34 about in the middle height wise . if the outer ujoint cap goes on with grease zerk up or down? I think up since that would put the battery ground tapped hole on the same side as the battery. True or false? Thanks Ken[/QUOTE]
Thanks Dave, I just found an old thread where you answered the same question for me! DA! Im getting old!!!! Ken
