Will a T5 transmission for a ford (unknown year) work on a 8BA Flathead. Seems what i have been reading is the S10 T5 is the go to choice.
Thanks in advance for everyones help
The late '80s/early '90s Mustang W/C T-5 is a better choice over an S-10 because of better ratios, internal improvements and higher strength, but the S-10 tail housing swap moves the shifter forward and next to the gear box. A 1" adapter will mate the trans to any '49-'53 Ford/'51-'53 Mercury bell housing.
Almost, you need the half-bell and the hogshead plus the adapter plate or a half-bell and one of the aftermarket cast adapters........
You just need this 1" adapter for a Mustang T-5 to bolt to the '49-'53 Ford/'51-'53 Mercury bells. A '51 Mercury is the one shown and is what I'm using in my avatar.
V8 Bob
Where did you get that adapter, I've been making them, but this is a better and cheaper way to go
Ron, I bought my adapter from Mark Kirby (MCF) about 15 years ago. They may still be available from him at Shadow Rods, and are from Modern Driveline, below.
http://www.safepay.net/cgi-bin/shop...xt&category=Adapters&merchant=moderndriveline
Believe Wilcap has them. V8 Bob what years of the bellhousing has the cross-shaft clutch fork setup?
The major production '51 Mercury bell housing was the only year for the '40-'48 cross shaft clutch release. ( JFYI, I'm using a '32-'39 cross shaft in the one pictured.)
A few early '51s used the '49-'50 stamped steel 1/2 bell and round patterned transmissions.
