Questions on frame paint
OK here's my plan for you. First, after getting the frame back from blasting or sanding whatever you do to it, first step is to paint it with Master Series primer. Apply two coats./ It can be sprayed or brushed. If you brush it,most if not all of the brush marks will go away. Then top coat it with whatever paint you choose. You can use lacquer, or enamel that has been flattened slightly. You can use single stage urethane with a flattener added or even BC/CC with a flattened clear. This all assumes you want less than a full gloss. You could even spray can paint it if that is all you can do. The key is using the Master Series first. You will have no rust problems at all, none.
Thanks for your help
