Nabco
And use a release compound on them when they go back in. I don't think Les says anything about this.
Not exactly sure what you mean by a release compound?
Never-Seize = release compound get it at the auto parts counter.
I was always told (and I've found it to be true) that if you're putting cold plugs in a warm engine, DON"T do them up any more than snug. Once he temperatures equalise, they will be tight.
Back in the early 70's, I bought a second hand car and decided to go through it. Man, were those plugs tight! I had a ring spanner (I think you Americans call them a box wrench) on one of them with a rope tied through the other end. I passed the rope out the front of the car near the radiator and tied to a post. I started the engine, selected reverse and backed away. When it came loose, it sounded like a rifle shot. The neighbour's cat was never the same.![]()
I use this a lot. Has graphite in it use latex gloves when you get the stuff on your hands or fingers it isn't easy to get off right away! Good stuff plumbers use it a lot. A small jar will last a long time only takes a dab.
I was told .035 for a standard compression engine
If using a 6.1 head is there a difference in plug gap?
