question on oil pump drive cover 46 ford flathead
nascarace
New member
How would you get the center piece out of the cover that the gear rides on between cam and pump to use in a new cover as mine is crack and needs to be replaced ?
The oil pump idler pin is pressed into the cover its not threaded. Since your original cover is cracked just use a little heat from a propane torch to warm the cover around the pin hole then just tap it out with a hammer and punch. Heat the new cover the same way and carefully press the pin into the cover.
I presumed the gear was this one in your discussion
If it isn't I have to see what you have.
R
If this is your cover then "RR" has given you the correct info required.
R
