MBI Houston
While driving down the road my ammeter went from a +4 to a minus 1. I looked inside the cutoff switch to see if the contacts were stuck. I discovered that the cutoff switch is a modern diode type. Not being able to decide if the diode was working or not I went to the next logical (in my novice mind) step. I tried to adjust the generator brush. I pushed it into a lower position and there was no change to the ammeter. I then pushed it to a higher position and there was still no change to the ammeter. I am assuming that the ammeter is ok since it shows a minus 8 when I turn on the lights or step on the brakes and then returns to the minus 1. Any thoughts on what my next steps should be? Thanks for you help.
Marshall in Houston
Marshall in Houston
