A-Jay
OK Guys I know this is kinda basic, but is it OK to use a floor jack at the bottom of the differential, near the drain plug on the rear end assembly to raise the car to set it on jack stands.
I have two sets of stands, the short set (2.25 ton) for the pair, only will extend up 17+ inches do you guys think these are big enough for the front or rear to get the wheels off the ground for a winter brake,wheel bearing,front end check. Thanks for your replys
