Question for Walt Dupont
My 34 Ford
Hi Walt, Thanks for responding to my 34 flywheel question and how to tell the difference in the flywheels. I only have the 11 inch flywheel and so I have nothing to compare the difference size rings to. I am hoping you can tell from the attached photo and tell me if I have an early one or a later one. Best regards and thanks.
This is probably the most polite bunch of people I've ever been associated with. Walt, you better jump in here quick!!
Lonnie
From the pic that looks like the wide ring gear, If that's a flat wheel on front It should be 59AB wheel 46-48 -- Have it drilled and balanced for a 9in. PP and it should work in your 34 engine. Walt
