question:bearings
29rdstrpu!
Are the 32-36 rear hub needle bearings the same as the model a? I purchased some new a bearings and the quality doesn't seem very good, I found some n.o.s. 32 bearings I would rather use if I can? Thanks
Mid 36 a hardened race was put in the hub, the later smaller roller bearing can be used too with the race, the large roller bearing is the same as A bearings
