christian
I recently honed my cylinders and installed new rings. Now have everything assembled and want to set the rod bearings. Was going to use the foil method, but there's too much drag from the freshly honed cylinders and rings to discern the proper clearance. Decided to use plastigauge. My question is, does the plastigauge go lengthwise along the crank bearing, or perpendicular along the bearing ??
