JT FORD
Having some trouble with my l949 Ford O.D. If I drive around town or short drives it works fine. But, if I drive 20 miles or so and the overdrive kicks out at a stop sign or light it will not kick in again. Just free-wheels. After
parking the car and using it again the next day or later it works fine until it has been driven awhile.
What I have found is, the voltage to the reply form the switch is 6.60 volts, but when I ground the THSW terminal and measure the voltage at the Sol. terminal its 3.76 volts. This must be enough voltage to engage the solenoid sometimes but not after things warm up......I will now remove the relay and look at the points and maybe clean them up
and see if the voltage increases. Or, do you think the relay is toast
Thanks for any help, have had OD in 49-51 cars and never ran into this
problem before.
problem before.
