Ok, so the crank bolt loosened up very easily, I’m talking about a 1/2 turn before I could loosen it by hand. And as you can see, there’s some metal
Shavings on the bolt. Also, why is a section of the bolt darker colored?
i like to take the starter out and use a pry bar on the flywheel teeth when fooling with a suspected stuck motor. you got more leverage farther away from the crank, and if it wont turn there....its stuck
