LukeCutler
I bought a reproduction Boyce motometer on eBay, and I have a few questions.
First off what temperature should a model A be running when it is in the operating, I'm going to buy a thermometer so I can check the temperature at the radiator fill neck. The temperature probe does not reach the water, but I don't think it is supposed to.
Also I had the engine running for about 30 minutes and the temperature on the motometer didn't even start to show a temperature on it until I shut the truck off, and even then it only went half way to the normal operating range. The engine seemed warm, but I didn't have a thermometer to check it.
Finally, I have several antique double flywheel gas engines, and with them I know that as long as you keep water in them they are not overheating, am I wrong in assuming that since the model A is not a pressurized cooling system that as long as it is not boiling the water out it is not overheating?
Sent from my E6782 using Tapatalk
