I saw an ad for a Model A chassis a couple of months ago. When I went to look at it I founf out it was really a speedster. Not a really great wooden body, but kind of cute. The chassis was what I was really interested in and it looked good; supposedly restored. The price was right, the engine fired right up and sounded good, so I drove it onto my trailer and brought it home. It sat in my garage until I fired it up yesterday to take it outside and flush out the cooling system and put in some fresh antifreeze. As I pulled out of the garage I heard a weird noise; not quite a grind but maybe a loud rubbing sound and the car shook a little bit. As I drove around the driveway the noise and the shaking got worse, but it only happened with the clutch engaged. Pushing in the clutch would stop the noise, even though the car was still rolling.
I put the car up on jackstands today, started it and put it in gear. I listened to the drivetrain through a cardboard tube and the noise seemed to be coming from the differential, but with a straight exhaust it was kind of hard to be sure.
If it was a bad throw out bearing, wouldn't it make noise when disengaging the clutch, or all of the time? Clutch operation seems to be smooth.
Does it sound more like a bad pinion bearing? Seems like it should make noise all of the time but maybe coasting with the clutch pushed in takes just enough pressure off to calm it down.
Any ideas? Thanks for your help.
