after the leafs are cleaned and lighly lubed i install the main leaf on the axle, then i get a long cener boit, stack the rest of the leaves, put the center bolt thru the leafs, the bolt is long enough to go thru all leafs then put on nut, and using two heavy duty quality clamps i start compressing the springs and keeping the nut tight on the spring pack, when all the leafs are compressed and bolt tight i cut off the excess of center bolt and remove the clamps slowly, that way i dont have to relie completly on the clamps when compressing, and i dont have to remove the center bolt to install the center bolt,and the spring is together and installed on the axle
