leadpot
Pulled the distributor out of my 29 & the inside of the shaft housing was dry, even had small amount of rust. I believe I have the 2 piece shaft, bottom of the distributor keys into another shaft at the bottom of the housing.
My question is should I pull the shaft occasionally and add oil? Could not find any info on lubricating the housing so may not even be necessary.
Thanks,
Thanks,
