JOES31
I am installing a new water pump tomorrow and was wondering if I should use a sealant on the gasket. The old one didn't look like any was used. If I should which one. Permatex, Yamabond, Indian Head? Any anti seize on the bolts? The studs were easy to remove except the top passenger side. That one made up for the easy ones but enough heat and it gave up.
I am using one from Snyder's, no leak greaseless with a new 2blade fan.
Looks pretty straightforward. Anything Suggestions are appreciated.
