zoegrant
I will be pulling the 272 Y-block engine out of my 55 Ford in order to install a rear main seal. What is easier, pulling the engine & ****** as one unit or pulling just the engine ????
The ****** is a T86 with a R10 overdrive & is in good working order.
I did try to install a rear seal with the engine still in the car but it still leaks so I will to do it with the engine out of the car in order to remove the crank shaft to install the seal.....so let me know what you think about pulling the engine with or without the ******....Thanks
