machine girl
arguing over what is easer and faster ? when doing a clutch job,pull the motor or rearend. what do you think??
Rear end is how I do it. Leave the spring attached, just be sure to put a big C clamp on it while it's sitting out of the car. You don't want that center bolt deciding to let loose while it's sitting in the middle of your garage. Or while you're bent over it.
I agree totally with Tom.Pulling the engine or the rear axle assembly to get at the transmission is pretty much a personal choice. It is whatever you are comfortable with, and your knowledge of doing either task. My preference is to pull the rear, regardless if an overdrive is attached. The reason being I have done it many more times than I have pulled an engine. I also have a roll around cradle and some high jack stands to support the frame. The cradle rolls under the back of the car and the rear axle assembly is lowered into it and then pulled out from under the back of the car and left in the cradle until time to re-install. The effort take about 45 minutes if I have some willing workers to help. By myself it takes a little longer.
Tom Endy
Tom Endy,
Thanks, so the idea is to "safe" the rear spring with a spreader, then remove the U bolts holding the spring to the frame... sound like $150 or so for peace of mind is good advice.
Attached photos were posted here on this forum recently by a fellow down in Australia that had a shackle bolt break while trying to remove the assembly without a spreader.
Had the shackle bolt broken after the assembly was out from under the car the spring would have pirouetted and likely broken the other shackle and flung the spring in any direction.
One of the photos show him working over the spring installing a spreader he later acquired. The center bolt could have let go while he was doing that. It can also let go while you are installing or removing a C-clamp.
Tom Endy
Perhaps a question for Tom about rear-end removal:
Would it be OK (safe) to remove the rear-end with the spring attached if a heavy duty springspreader was ALSO loaded/mounted onto the spring?
Thanks.
