PTO for non-synchro 4 speed
green bay
wi
Looking for a back up or replacement 6 bolt pto for a non synchro 4 speed manual. From what ive found a model aa had same or exact pto so im guessing the range is between 29 to early 50s. The gear should stick out about 1 inch from the housing and have 25 teeth.
Hi Bobby; I have at least one, as I part out the trucks here in Oregon. You may find one locally in time though. They are not expensive say $50 plus shipping. Note though the output shaft can point to the front or rear of the truck, and you need to specify. Later Newc
I have a couple PTO's, will check to if any are straight gears. For some reason I am thinking one has a straight and a helical gear and the other just a single helical. I know the bolt pattern is right to fit the AA and BB transmissions. Rod
