'31 Patina
Can someone direct me to the proper steps on adjusting the brake rods on a '31 coupe? I have the Les Andrews vol. 1 manual and I'm reading through the service adjustment section for brakes but I'm just not fulling understanding the brake rods.
The cross shaft actuating lever on the car isn't in a vertical position like the manual suggest. The actuating lever is at a slight angel when there isn't any pressure on the brake pedal but when you put full pressure on the pedal then the lever is in the vertical position like it should be.
I'm in the process of re-doing the brakes but before I start I want to fully understand how to adjust the brake rods properly.
Also when the brake rod is attached to the front brake actuating arm should the arm be straight up or at the 15 degree forward tilt? Or is the front brake actuating arm supposed to be at a 15 degree forward tilt when the rod is NOT attached to it.
I'm learning as I go and I'm following the manual but sometimes it helps to hear other verbiage so I can understand it better.
Thanks for the help!
