Henryat1140
Back in the 80's I had a dual fuel F-150. It was a satisfactory way to run the truck, no problems. I did not experience rough idle when the engine was cold. One switch and away you go. I was in a business that used a lot of propane, and it made economic sense because I got it at a good rate. I really did not notice that much of a power loss on propane, nor was the mileage that much less.
One side benefit was teasing/aggravating my dates. Lots of times I would run almost dead empty on gasoline and of course the gauge showed empty or maybe below empty.
It never failed when a girl got in the truck, eventually she would notice the empty gauge and make some remark about "don't you need to get gas?", to which I would say "no, this truck will run a long while with the gas gauge on empty" - which was literally true because the truck was running on propane.
As the evening progressed the girl would get more squirmy about the empty gas gauge, but I just would keep repeating that it was OK, not to worry. Strung some of them along for a long time.
If propane was readily available I'd consider switching, but around here it's not; only a couple of places, not convenient.
