Gary in Mozarks
Well we got the rear wheels and wishbone out of the panel frame tonight and filpped the frame over so I can better get at the running board bolts. (pictures in the morning) I also need to remove and transfer the spare tire carrier.
After reviewing everything I have decided to transfer the rear extension and use the pickup frame. The patch is only 4x4 and right at the dogleg. I think it will be less work than transfering the drive train. I will start sandblasting the frame tomorrow. I will paint it with rustoleum satin black (50/50 mix of flat and gloss black) 7.99 a quart at the local elevator.
I am going to remove 4 riviets to straighten the cross brace right in front of the muffler. I can do a better job of it out of the frame and rivet it back. I bought a bunch of shovel rivets at an auction and they are the right size. I just have to shorten them.
The body is supported well on jackstands. I have a problem with the lower right corner at the back door. The seam seperated in the process of jacking up the body. I am going to have to bring that back together and keep everything square.
It looks like somebody used a pry bar to get the left rear door open at some point. I have a dent right next to where the top bolt latches into the upper recess, above the left rear door. That one is going to take some thought.
Gary in Mozarks
Gary in Mozarks
