John
I recently purchased several repro TR83A metal valve stems from a major Model A supplier to install in my 19 inch tubes. Upon installation, I found that the valve cap ordered at the same time would not fit on the valve stem. I thought that it would not be a problem until the person who mounted the tires found his air nozzle on the tire changer would not fit the stems also. I then found that my portable air compressor would not fit the thread on the stems. I measured the thread diameter of the stems and found it significantly oversize. I then purchased the proper thread die for the stems (try to find that thread series) and rethreaded the stems. The die cut quite a bit off the threaded area proving that the stem was oversize. I checked an old reproduction valve stem and did not have the oversize thread problem.
Was it just my luck with these 4 stems or am I missing something here? Anyone else have this problem?
John
John
