Problems starting when hot
moonraker
Dear friends, I took my '39 Fordor for a short trip around Moscow and everything was fine until I got stuck in a traffic jam. The temp crept to ~200 degrees. Then I accidentally stalled the engine and it didn't want to start with a starter. The smell of gas was an indication of no spark. I asked bystanders to push the car and it started immediately. Can you tell me what the cause possibly be?
Thanks in advance!
Any loose wires or bad grounds?
Did you "pop the clutch" to get it started again while being pushed?
When you indicate that it did not start , would the engine turn over with using the starter and engine would not start or did the starter not even turn over the engine.
Vic
Vic
Sorry, forgot to mention - the starter had difficulty turning the engine the first one or two turns and then it continued to turn the engine with now problems, as fast as it does when cold.
All wires look fine, I have battery kill switch on ground terminal with ground two ground wires - one to the body and one to the stud on a passenger cylinder head
Can you explain what "pop the clutch" means? I press the clutch, shifted into the second gear, once people pushed the car fast fast enough, I released the clutch - it started right away.
do they have reg gas in russia or the ethnal crap if you pushed it & it started it might have flooded or the gas boiled
we are lucky so far - no ethanol gas in mandated and sold in Russia. In some rural areas you can still get 78 octane gas, but it's being phased out by refineries.
I don't think I flooded it since I know how to start hot carburated engine - with the gas pedal held to the floor
That would be popping the clutch
This is what it means in American slang.
Sounds like a marginal coil to me. The coil becomes hot and looses some of it's "zing". It will run all right when it's the only thing taking electricity, but when you add up the extra load imposed by starting a hot engine, there's just not enough there to turn it over and produce enough spark from a coil in a degraded condition.
moonraker, I suspect that your starter needs to be rebuild or that your battery needs replacement. With a good fully charged battery the starter should keep cranking.
Check the ballast resistor under the dash, if it has one. My 41 would do the same as what you described. I cleaned all the grounds and connections on the fuse block where the resistor is locatedfd and no more hard hot starts. Do this first before buying more parts. Good luck Al
Thanks everyone for your input, I really appreciate this!
the battery is fresh, the starter has about 2000 mi on it, should be fine.
I'll start with checking ballast resistor and all the wires. Can this problem be attributed to a coil condenser?
