ersatz
I have a 1946 Ford 1/2 Ton Pick Up with flathead V8. I have one of E.J. Whitney & Co. (Fullerton, CA.) 40 AMP alternator conversions. The alternator is only 2-1/2 years old and everything worked just fine.
Everything was fine until 3 or 4 months ago. Then slowly a problem with my AMP guage bouncing wildly back & forth when driving began to occur and get progressively worse. Now it happens all the time. Took it to a starter repair shop today and had it tested. They checked the battery & everything with meters and nothing showed it face. I was told it could be the Amp gauge, or a bad ground.
I've got the positive ground cable for the battery grounded to the firewall. Also a ground from the firewall to the block. What other grounds do I need?????
Your HELP appreciated!
